!!! FI light keeps coming on !!!
- Gazza
My Crim's FI light keeps coming on and im a bit concerned.
It hasn't lost power at all and runs exactly as it should but the light stays on now.
It happened to me a little while ago but i put it down to bad fuel but the last
couple of times ive been out for a ride it comes on amd stays on.
Any help as to what could be the problem & how to fix it would be
a great help.
Thanx in advance.
a great help.
Thanx in advance.
2005 zx10r
Exhaust valve working?
There is a way to check the codes somehow...
- Gazza
Re: !!! FI light keeps coming on !!!
I have a full akro system on it , so would there even be an exaust valve on it ?Wattie wrote:Exhaust valve working?
or is it the black box with the hex looking nut that turns when you
turn the bike on ?
2005 zx10r
- Glen
That's it. Has the light come on since you put the Akra on?
You normally stick a little doovey on instead of the hex thingy to stop it rotating and it tricks it into thinking the exhaust valve is still there
The box may be dead. Happened in robracers 6.
If the code says its that, then get a servo buddy and get rid of the servo.
Yeah it's the hex thing under the seat.
greenmeanie
- Gazza
Servo is the problem, just checked it and its jamed up but if I turn it by hand it will work but not by itself.
thanx for the advise and help guys
much appreciated.
Have already ordered a Servobuddy from the website you put up greenmeanie cheers mate
much appreciated.
2005 zx10r
See money fixes all !
- Gazza
FI light problem solved.
Servo buddy installed and tested @ the old rd race track
Yesterday and has been tried & test under the most extreem of condition.
Now i have an error free crim once more.
Thanx to all who steered me in the right direction as to the problem
2005 zx10r
greenmeanie
I'd heard they were unrelaible those CrimsGazza wrote:FI light problem solved.
Servo buddy installed and tested @ the old rd race track![]()
Servobuddy is fantastic
- Strika
Yeah, I had that problem with one of my bikes. I removed the globe!
