Venhill Braided Lines
Anyone used or using Venhill Braided Lines. If so, your thoughts and opinion. Thanks all.
- born green
Re: Venhill Braided Lines
I run hell.myzx10r wrote:Anyone used or using Venhill Braided Lines. If so, your thoughts and opinion. Thanks all.
But i fitted a set to my mates 08 ZX10, was impressed by them tho, their english and a lot of BSB teams use them.
They differ from others as in they use a flared flange and nut, like a car brake line, a bit of a fiddle to fit, but they fitted well, and look very well made, the advantage is that when fitted, u can make sure they sit right before u tighten up..
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
Thanks. Looks like they might be the ones to go for. Id rather hear opinions and then make up my mind. I agree that they do look horn!
- born green
When he was getting the lines, i told him to get hell's, but when he arrived thats what he had..tristan from redline motorcycles got them for him, as they were cheaper than hell and goodridge, but anything is cheaper than goodridge!!myzx10r wrote:Thanks. Looks like they might be the ones to go for. Id rather hear opinions and then make up my mind. I agree that they do look horn!
Go for it, they are very well made, just take care fitting them, and make sure the flanges are done up right...
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
If they use a flange & nut they will not be ADR approved....they have to be press fitted to pass
- born green
Thats what i 1st thort, but on the packaging they say they are?? and from memory they have the tag on the lines like hell ect... with the adr compliance... he will have his bike at work tomorro so will double check...robracer wrote:If they use a flange & nut they will not be ADR approved....they have to be press fitted to pass
Will get back to this... im 99% sure they did..
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
I spoke to an Australian supplier and they are approved. I will triple check and I think I'll have a mechanic fit them to bleed the brakes also
Tagged = Good but still check on it that its for AUS compliance, let us know what you find?
We make our own lines for the race bikes with similar fittings & have been told if they can come loose (flange) they cant be tagged hence the press fitting for compliance for the locally made ones.
For the ADR they must conform to SAA, SAE, BS, JIS, DIN, ISO or ECE Standards, or FMVSS 106 Brake Hoses
- born green
Ive just double checked again, and my understanding is they are...
They say they are ADR, DOT, and TUV compliant, dont know what TUV is...
If not sure their nun is 02 9484 077, thats the distributer's number
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
