I am trying to locate a fairing bracket that attaches the left Fairing Lower to the Frame. The attaching point is just in front of the Coolant Reservoir on the main top part of the frame.
If ANYONE can locate it in the OEM parts Fiche I would be amazed as I have used this extensively for other parts and this appears to be the only bracket that doesn't rate a mention.
The parts that attach the Fairing to the Bracket are: 92015 (Bolt, Socket), 92143 (Collar) and 92075A (Damper).
Please note it is NOT Bracket 11050 as this is the rear, lower mounting bracket. Please confirm.
Cheers & beers - Phoenix
2000 ZX-6R Fairing Bracket Mystery
- laidback
Re: 2000 ZX-6R Fairing Bracket Mystery
Have you checked the radiator section?
Does this point not attach to the radiator?
- roastdinajima
http://www.cornwallkawasaki.co.uk/shop/ ... am&id=1696
35011? that bolts to the engine and holds the rad and fairing.
