93 ZXR 750 / 900 Conversion
ZXRJed
Bike: ZXR750
Post by ZXRJed »
I have just got my hands on what's left of a ZX9. I am looking at transplanting the 9 motor into the ZXR.
I have had a look at this website - http://homepage.ntlworld.com/webzxr/zxr ... xr7-9.html
I can't seem to find any other info on coversions on the web.
Has anyone on this Forum done this conversion? And is it as easy the the above link suggests?
Cheers, Jed
So the plan is to take the motor out of this pig
And put it into this
fezzick
Re: 93 ZXR 750 / 900 Conversion
Post by fezzick »
I am assuming that the "pig" is a stat right-off, yeah? Because, otherwise, what's left could be a good project for someone else. :)
I started out with nothing and I still have most of it left. Phil
www.halfofmylife.com
Bogan
Post by Bogan »
Are you certain that's a ZX9? I didn't think any of them came with upside down forks?
Are you at least certain it's a 900 motor?
Tony
I have become race...
jefflthomas
State: Overseas
Post by jefflthomas »
as i recollect the left hand oil return was the tricky bit...but i think we reduced the width of the banjo
it was a long time ago & there weren't any instructions...LOL
'01 ZRX1200R ZR1200A1
Nelso
Post by Nelso »
Bogan wrote:Are you certain that's a ZX9? I didn't think any of them came with upside down forks?
The later models did.
Bogan
Post by Bogan »
Macca's 2003 model doesn't?
Tony
The B models did and that bike in particular is a B2-4? 9R. Forks and callipers give that away.
That motor will fit into the earlier 7's no worries and is a common transplant, from memory its a case of elongating the top engine mount holes a little and she slots straight in and I think as mentioned the oil line banjo may need some attention, everything lines up AFAIK.
Ask Stace, he has done one. ;)
Nelso
Post by Nelso »
Bogan wrote:Macca's 2003 model doesn't?
I just went back and checked some old photos and my '03 trackie didn't either! I was sure they did as plenty of people put upside down forks off ZX9's onto ZRX's. Now I am confused. :?
This isnt about the 2003 model. It is about the ZXR models not the ZX7R or ZRX bikes.
As his link reads... Conversion Guide for '91 to '95 ZXR750/9R
ZXRJed
Bike: ZXR750
Post by ZXRJed »
Jonno wrote:The B models did and that bike in particular is a B2-4? 9R. Forks and callipers give that away.
Cheers Jonno - Thanks for the info.
I'll keep you guys updated with the progress. Will probably pull the 9 out this weekend and give it a decent clean and if time permits get it painted.
fezzick
Post by fezzick »
The next question is, does the 750 motor fit into the 9 frame???
timmyrocks
Post by timmyrocks »
No the mounts are different :P
Team Crash "09"
WR125 2004 Husqvarna :P
Nelso
Post by Nelso »
Jonno wrote:This isnt about the 2003 model. It is about the ZXR models not the ZX7R or ZRX bikes.
So clear things up then. Why would ZX9's have upside down forks in the B models and then go back to conventional forks in later models?
Daisy
Bike: GTR
Post by Daisy »
Hey Jed, what are you doing with the rest of the nine? I can see a few bits there to fix up my pig. :D
Oh yeah, what carbies are you using? The 9 has ram air.
