A friend is looking at a set of mufflers for her 08 Z1000>> http://www.ebay.com.au/itm/GP-Carbon-Ex ... 255fd90a86
Ive had a look at the bike & the standard mufflers have an exup sort of arrangment, with cables going into the link pipes.
Can someone tell what this is & can it be disconected without any problems, & does this the new mufflers need this to work etc etc.
Thanks
2008 Z1000 help needed!!
- Team Monster
Re: 2008 Z1000 help needed!!
Mate I have this model zed and when I put on my yoshi slip ons just disconnected the cables at the servo and the rest came away withe the exhaust....it is only in the right hand side if I'm correct....
And it dosnt need a stopper on the servo like my zx6 did...hope this helps
Mate that really helps, thanks. So just dissconect & Bob ya uncle?
- Team Monster
Yep too easys man wrote: So just dissconect & Bob ya uncle?
I know it's not in english but this give's you the general idea where it it located
The purpose of that valve was to increase back pressure at lower RPMs to give better low end performance. Jim Beam Decreases back pressure on the brain, only if you have 10 to 35 shots.
- Chitchats
oldman wrote:The purpose of that valve was to increase back pressure at lower RPMs to give better low end performance. Jim Beam Decreases back pressure on the brain, only if you have 10 to 35 shots.
Pigs arse, there is no mention of what happens to the back presure after 35 shotsChitchats wrote:oldman wrote:The purpose of that valve was to increase back pressure at lower RPMs to give better low end performance. Jim Beam Decreases back pressure on the brain, only if you have 10 to 35 shots.![]()
Best advice yet.
