My lights have just gone out but they still work when i press the pass button?
Ive checked all fuse and earth wires all look good i'm thinking something in the switchblock??
Help
only have pass lights
- tim
Re: only have pass lights
Assume it doesn't from what you said, but does high beam work when you switch to it?
no lights at all low or high not untill i hit the pass switch
- Six Addict
- Pinchy
- Bike: Ducati
just change the bulbs? but maybe also just double check all the connections - try up behind the dials, there will be plugs up there too
- Blurr
Your switchblock should be waterproof but it doesn't always remain that way.
Try some WD-40 into the block around you headlights button. If that fails open the block up as it sounds like a loose wire
