ohlins setup
- born green
ohlins setup
just a quick qestion, any of u guys that race or do a lot of track time on the 06/07 10, with a ohlins ttx, i would be very interested in any feedback, spring rates ect. fitted one recently two my 07 10, have been running a very modifyied oem one. had my head around it. had one ride day after fitting the ohlins. running dunlop contol slicks, 200 rear, soft front. i took it two broady, knowing the spring was way two light 9kg.thats what it came with. im off twomorro to c a ohlins guru. 11kg is what im changing two?? any ideas would be good two hear, o and im about 92kg ready two ride
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
- Blurr
ohlins setup
Wattie is your man here, he has a TTX rear
ohlins setup
I dunno what spring I have...
But Zenodamper did mine. Its not stock internal either.
- born green
Re: ohlins setup
have spoken two stewie winton quiet often over last couple of yrs, 11 kg was a rate that came up two start with. do u run a lot of ride height? kno of one 07/10 running 9mm spacer, im running 5mm and one full turn on ride height adjuster. thats depends on tracks ofcourse. but i tend two set it and leave it.
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
ohlins setup
i run stock height. I had it jacked up before, but couldn't get decent drive.
My old shock was "Stewie winton fettled" but inside was straight from the factory once pulled down and serviced etc.
- born green
Re: ohlins setup
see how i go, rdo twomorro so got shock out, take two krozztune twomorro, run the 11kg spring, take two broady again and play with it see how it goes. planning on going two E/C on 17 dec,hope alls well and ninja10 sorted!!
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
- Blurr
ohlins setup
See ya on the 17th
