Quickshifter - anyone want one.???
These are the same as the one I am running and work the same as the dynojet one.
They allow you to upshift without backing off the throttle.
They are called PK power and work with a power commander 3 and 5 (PCIII / PCV) -also yamaha race ecu and rapid bike ecu...
Cost is $130 shipped - with no rods, I found it better to set it up and grab a rod from Pete (Kaneg) and trim it to suit with a bit of threaded rod if necessary (I have plenty of that if you need it)..!
I can get them to supply the rod as per the pic for $10 extra, but Petes are a better option.
http://www.pk-power.com/quickshifter.php
P4nza
Re: Quickshifter - anyone want one.???
Post by P4nza »
Misleading title... "want" is not the same as "for sale"!! :lol: :lol:
budgienutz
Post by budgienutz »
they dont hook up to dynojet pc111 do they?
Have you ever looked at someone and thought.
"YOU were the load your mother should have swallowed"
budgienutz wrote:they dont hook up to dynojet pc111 do they?
Read his post,
It says "power commander 3"
What does pc111 stand for?
P4nza wrote:Misleading title... "want" is not the same as "for sale"!! :lol: :lol:
I don't know about you, but most material items I want cost money. :-)
Oh and they don't work on Ninja 250's, so move on.. :-)
Baddie
Post by Baddie »
Im keen but do i still need an Ignition module to fit my PCV?
:D
http://superbikesource.com.au/
For aftermarket racing products, from Annitori Quickshifters to Race fairings.
http://tarmactalk.com/forum/forum.php
These plug into a PCV (power commander 5) and a PCIII (power commander 3), you then just run the kill shif program - which I have, and set up the RPM and the kill time and your off.
All I need to know is, if your up shift is a push or a pull on the shift rod... (my 05 is a push - in race pattern it would be a pull)
Baddie
Post by Baddie »
Im running Gp shift pattern.....As you leave only 30min away I may need to bring it over... :D :D :D :D :D :D :D
budgienutz
Read his post,
HAhahaha sorry i didnt read it properly,it will fit, sweet as.
Ill talk to the minister of war and finance and see if she will let me buy one...wish me luck!
Supafrog
Post by Supafrog »
Looks interesting... but... why would i need one? :roll:
Supafrog wrote:Looks interesting... but... why would i need one? :roll:
If you don't know why, you don't need one.. :-)
I dont NEED one yet :roll:
Supafrog
Post by Supafrog »
Yay! You just saved me money!! Thank you! :lol:
MAXUMIS
Post by MAXUMIS »
the quick shifter on a PC111 has to have the ignihon module to make it work!!!!!!!!!!!!!!!
life starts at 200 kph!
Baddie
Post by Baddie »
MAXUMIS wrote:the quick shifter on a PC111 has to have the ignihon module to make it work!!!!!!!!!!!!!!!
Are you 100% sure and have you ever installed the brand Madkaw is offering???
:D
