Water in fuel tank!!
ZZR 250, 600, 1100 & 1200
Matty C
Bike: ZZR1100
Post by Matty C »
I was riding to work the other day and getting down on fuel the bike stutters as I attempt to overtake so I flick it over to reserve then it dies. I pull over, check the fuel, seems to be plenty splashing around but will not start. A mate of mine with a trailer picks me up and we drop it around to the shop, he diagnoses a fuel pump and orders it. When it arrives the next day he takes out the old one puts it on the ground and rusty water comes out!! There was apparently over a litre of water in the bloody tank :oops: all rusty too, must have been there for a while. In the 11 months (16000kms) I've had it I've only used reserve once and that was to see when it would be required. When I flicked it over this time it must have sucked up water instead of fuel...
He flushed tank and carbs with metho several times It seem the drain hole near the filling cap was blocked... Anyway $540 later she's a goer again just need to flush the carb bowls in a little while to make sure she'a all clean.
I'll be checking that drain every time it rains from now on...
Matt
It's the closest thing to flying...
Re: Water in fuel tank!!
Matty C wrote: There was apparently over a litre of water in the bloody tank :oops: all rusty too, must have been there for a while.
:shock: Geeezzzz..... does that mean your fuel cap rubber isn't sealing well against the top of the tank? Or would that happen to any bike where the water drain gets blocked?
might have just picked up the dregs from the servo when he filled up last ;)
Matty C
Bike: ZZR1100
Post by Matty C »
Six Addict wrote:might have just picked up the dregs from the servo when he filled up last ;)
possible I spose...
If not yes the seal does not work. The more I think about it 1 litre is many many rings of water around the seal... :? But then again we have been getting an awful lot of rain... and I ride rain hail or shine ...
MAXUMIS
Post by MAXUMIS »
metholated spirites gets rid of water
life starts at 200 kph!
jefflthomas
State: Overseas
Post by jefflthomas »
i switch to reserve after every fill up for about a 100km to avoid that sort of thing
'01 ZRX1200R ZR1200A1
Matty C
Bike: ZZR1100
Post by Matty C »
jefflthomas wrote:i switch to reserve after every fill up for about a 100km to avoid that sort of thing
Good idea jeff but I'd prolly forget to switch it back to on.... :oops:
jefflthomas
State: Overseas
i forget all the time mate then i look at my tripometer when i'm almost supposed to actually be on reserve...LOL
