um now it wont start (ZX6RR)
MrFaulty
Post by MrFaulty »
Yeah, throw the jokes at me about my name etc - I think I must have ridden over a black cat!
On the weekend I was adjusting, cleaining and lubing my chain but it is no good so have ordered a new one, the bike started on the centre stand but was making a racket because of tight spots in the chain (only when I put it in gear). Now it simply wont start, keeps winding over till the battery is flat :(
I have checked the main fuses (under the seat). Also of note is that I replaced the stator recently but I have ridden about 200kms since then with no issues.
Any suggestions about where to start looking - I was going to start by pulling each of the coil packs out and checking for spark but I really doubt theis is the problem. I am thinking more likely it is some hidden fuse or relay that may be gone.
Any suggestions appreciated and all ridicule accepted!
Thanks
Ben
Re: um now it wont start (ZX6RR)
It's just no fun anymore because I feel sorry for you now :( hope you get it fixed easily and quickly mate.
it is in neutral isnt it?
MrFaulty
Post by MrFaulty »
Yeah, in neutral:(
Team Monster
Post by Disco »
Does it have fuel :shock: :lol:
is the sidestand down? is the kill switch on? :shock:
Check wiring, plug connections in loom, switch blocks for corrosion and spiders ;) earth connections, side stand and clutch switches.
Fuel tap is on, tank breather clear, hoses and filter ok etc.
all of the side stand/center stand/switch block/kill switch/neutral concerns won't be it because the starter motor is cranking right?!
ratfink_nz
Bike: Ninja 250
State: Overseas
Post by ratfink_nz »
Not sure about ZX6, but my ZXR will start with sidestand down. It only cuts out when it's in gear and I release the clutch.I Used to think I was stalling it, took a while to figure out. They are all different some will allow starter to turn but no ignition, some don't allow starter to turn. I would definitely check the stand cutouts
EDU
Post by EDU »
It does sound like a side stand sensor... I'd check that even if the stand is up 'cause they're known to play up regardless of the bike you ride.
MrFaulty
Post by MrFaulty »
Ah, thanks, how do I check the stand sensor, simply run a by pass?
MrFaulty
Post by MrFaulty »
although if the sensor is stuffed that would be the same as the stand being down and then it shouldn't wind over?
EDU
Post by EDU »
I'm not sure how it goes on your bike... mine won't turn but I had other bikes that would.
MrFaulty
Post by MrFaulty »
Certainly worth a look, thanks.
MrFaulty
Post by MrFaulty »
ok, have it narrowed down a bit
looks like a fuel problem, fuel pump is working (checked). Disconnected fuel pump and wanted to start for a second, then backfired. Reconnected fuel pump and after a bit of trying, figured out it will start if I crack the throttle open and then I can back it off a bit but as soon as I back it off to much she stops. Also, when I have it running, the FI light is on on the dash.
Any suggestions about where to look. Also, if I can't find the problem, will it hurt to ride it like this to get it to a mechanic?
A mate suggested it may be to do with valve clearances as I am going to adjust check and adjust them but it seems to much of a coincidence that as soon as I plan this the bike plays up, also it wasn't running too bad before this happenned.
Thanks
Ben
