ZRX 1100 WONT START
clanga61
ZRX 1100 WONT START
Post by clanga61 »
HEY all my rex wont start,now im not into all the technical names of bits and pieces so lets go, the battery is charged the kill switch is off the neutral light is on but when u hit the start button nothing happens except a relay under the seat with a 30amp fuse is clicking could it be f*****d thanks. Clanga
CLANGATOUCH THE MRS,PAT ME DOG,BUT DONT FUK WITH ME BIKE!!!!!
"IF YA CANT MONO IT JUMP IT"
Re: ZRX 1100 WONT START
Just a guess but Id say new battery time :)
h.b.bear
Post by h.b.bear »
agree with above :) battery is stuffed ;)
craig mac
Post by craig mac »
had a similar problem with my zx9r recently. I checked the battery voltage while trying to start, it was ok. I tapped the clicking relay while trying to start and she fired up.(I'm going to replace the aux starter relay). If the battery is buggered replace it with an AGM. good luck.
fezzick
Post by fezzick »
Wot they said!
I started out with nothing and I still have most of it left. Phil
www.halfofmylife.com
clanga61
Post by clanga61 »
Cheers Guys,i was just going to get a new battery but when i put it on the charger it was fully charged,that made me think of something else,will try battery swap,CHEERS
sounds like the starter solenoid might be sticking ? This happens on all sorts of bikes...
You need to have the specific gravity in the battery checked. It may read 13v on the multimeter, but that is not the whole story....
craig mac
Post by craig mac »
monitoring battery voltage whilst attempting an engine start will give you a good idea on whether or not the battery is the cause of the problem.
clanga61
Post by clanga61 »
New Battery :D :supz:
