ZXR fork springs
netbikes
Bike: ZXR750
ZXR fork springs
Post by netbikes »
Does anyone have any specs on H1 fork spring length and ware limit?, The front end sag about 1 inch just sitting, and there doesn't seem to be a lot of rebound.
cheers.....
chris at www.netbikes com au
It's too late when you're in the ground.
duspeed
Bike: ZXR750
Re: ZXR fork springs
Post by duspeed »
Zxr H Front fork spring free length is 387.5mm Service limit is 380mm
Also fork fluid is 135mm +or -2mm below from top off inner tube (fully compressed ,without main spring)
Dus
netbikes
Bike: ZXR750
Post by netbikes »
Thanks Dus, I did get that info from the manual too but I still wasn't convinced, have checked out another the same model since and it is the same.
I have pretty much finished the restro now, just waiting on a few rubbers from Kawasaki to arrive so I can fully fit all the fairings.
cheers.....
