ZX2R Sprocket problem, please help.
Tilley1991
Post by Tilley1991 »
Gday all, got my bike fixed up and running, went for a ride out last night and had issues with my chain, by the end of the ride last night i almost lost the sprocket off the back wheel, it has come loose and is probably as loose as a *insert generic sexual reference*, now can anyone tell me a quick way to fix this problem since i think the internals of the sprocket are flogged where they go on the shaft, or possibly have an old sprocket i can buy off them?
Tilley1991
Re: ZX2R Sprocket problem, please help.
Would a ZX2R Sprocket be interchangable with any other?
GPZ_Jim
Bike: GPz500
Post by GPZ_Jim »
loose as in the mounting nuts? know anyone with a rattle gun? :)
Tilley1991
found the problem, shat a bearing that sits inside the sprocket. might order a few parts but not sure where from..
6maniac
Post by 6maniac »
Tilley1991 wrote:..... might order a few parts but not sure where from..
You could try typing "NSW Kawasaki Dealers" into Google ......... :roll:
Deanoseadog
Post by Deanoseadog »
Just get it out, measure it, and check out the SKF catalogue online, get a part number. Go to local bearing supplier and buy a new one. You can probably skip the measuring step and just take it to the local bearing shop...but you'll have to answer a bunch of stupid questions that are really irrelevant. Sometimes you can get lucky at Repco.
Bearings have to be one of the best value for money items left in the world! So cheap for what you get.
the kid
Post by the kid »
Tilley1991 wrote:found the problem, shat a bearing that sits inside the sprocket. might order a few parts but not sure where from..
Clean off the bearing and see if there are any numbers on it . Take those numbers to any bearing supplier and see if they can supply a bearing to suit .
Failing that take the parts with the flogged bearing remains in them to the bearing shop . They should be able to measure them up for you .
If its a special one of Kawasaki bearing , then a Kawasaki dealer is the go .
Tilley1991
i think i will replace all the rear bearings and the rubbers as well as the sprocket while i am at it and the only problem with getting the numbers off the bearings is that all that is left of the bearing is 3 ballbearings that are stuck to the grease the rest is gone lol might have to get the parts off a kawa dealer
