The lights are on but no start.
- Greenblood
After getting the 7 back together & checking all the wiring I was thinking wonder if it kicks over.
It didn't go to plan. ignition on, switch to run, hit the button & nothing.....I have checked the usual stuff fuses & connections
I did notice the starter relay was corroded at the plug but cleaned & lubed that.....still no go.
I have lights in the dash, indicators, horn ect. but no go.
Does anyone know what I have missed??
2017 ZX10RR Road
2006 ZX6R Race Bike
1997 ZX7R Pirate MkII
2006 ZX6R Race Bike
- Ratmick
- Team Hornet
Re: The lights are on but no start.
Clutch switch, side stand switch, neutral switch...?
Mick
Mick
- Greenblood
Thanks Mick I was thinking about that last night but the bike was in neutral so it should not be an issue??
2017 ZX10RR Road
2006 ZX6R Race Bike
2006 ZX6R Race Bike
- Six Addict
- Pinchy
- Bike: Ducati
Unless the switch telling the bike it's in nuetral is broken...
- Greenblood
the neutral light is on so I guess it's working.....
2017 ZX10RR Road
2006 ZX6R Race Bike
2006 ZX6R Race Bike
- timmyrocks
Does it have a clutch switch?
Is the starter solenoid making a clicking sound at all??
Tried jump starting it?
Try bridging the starter solenoid with a screw driver
Check earths.
Get the multimeters out and start following voltage along the starting circuit, have a look at a wiring diagram and test all switch etc etc.
I hate electrics lol but this is what I would be doing, not in order though, always start simple
Cheers Tim
Check earths.
Cheers Tim
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
- jefflthomas
- State: Overseas
main ground to motortimmyrocks wrote:Does it have a clutch switch?
Check earths.
'01 ZRX1200R ZR1200A1
- Kev
I had the exact same problem Joe when I fitted the clutch MC I bought off you, I forgot to connect the clutch switch.Ratmick wrote:Clutch switch, side stand switch, neutral switch...?
Mick
- Greenblood
kevZX9B2 wrote:I had the exact same problem Joe when I fitted the clutch MC I bought off you, I forgot to connect the clutch switch.Ratmick wrote:Clutch switch, side stand switch, neutral switch...?
MickBike was in neutral, I had a neutral light, clutch was pulled in just in case, battery was fully charged, but absolutely nothing when I hit the start button, not even a click at the starter solenoid. Hope this helps.
I checked the clutch switch hoping that it was the problem but it was pluged in & fine.
looks like I will be out there on the weekend with the multimeter.
2017 ZX10RR Road
2006 ZX6R Race Bike
2006 ZX6R Race Bike
May sound funny but bypass / check the kill switch on the switch block ...... all electrics are on with the switch off
- tim
I had logged on to say exactly the same thingrobracer wrote:May sound funny but bypass / check the kill switch on the switch block ...... all electrics are on with the switch off
The last project I got.... the seller is going naaa shes stuffed mate .... you can have it cheep
Turns out the kill switch contacts were farked...... bike ran perfect
Joe if All electrics work except start so its the first place I would look.
- Greenblood
Spot on Rob, the switch was playing up.
A strip & clean & it's all good.
2017 ZX10RR Road
2006 ZX6R Race Bike
2006 ZX6R Race Bike
- timmyrocks
nice
Team Crash "09"
Team Crash "09"
Awesome Joe, so when we going for a ride?
