clutch springs
Stuzrx
clutch springs
Post by Stuzrx »
Can someone please give me the clutch spring torque settings for Z900,
Thanx in advance,
z900/zx9
Re: clutch springs
Post by z900/zx9 »
I will have a look in my manual tonight and let you know ;)
Stuzrx
Re: clutch springs
Post by Stuzrx »
Thanx,cheers.
z900/zx9
Re: clutch springs
Post by z900/zx9 »
Ok as i suspected just do the clutch springs up tight butcross tighten presure plate spring bolts gradually and evenly.
They only offer torque setting for clutch hub hub nut 100 ft lb chain drive 90 ft lb shaft.Make sure the push rod is grased and pushes smoothly.also make sure you soak the friction plates before instilation. :lol:
Stuzrx
Re: clutch springs
Post by Stuzrx »
Thankyou Sir,appreciate your time. :kuda:
