Engine surging
King Nicholas
Engine surging
Post by King Nicholas »
I learned something today.
My bike engine was cutting in and out within a second for no apparent reason at random rev ranges.
It caused my bike to throw me forwards violently and then almost spit me off the back.
This meant I had to ride the rest of the way home with the clutch in my fingers to prevent it from happening again.
If it surged while I was in a corner I would have gone down for sure.
Turns out it was not the fuel filter but my secondary throttle body had seized up.
The primary throttle body is controlled by my hand/throttle and the secondary throttle body is controlled by my ECU.
This meant I had incorrect amounts of air in my fuel air mixture, hence the surging and a bike that idled at 2-3k RPM.
My bike has a brass throttle body which does not require lubrication.
Thanks to Brighton Kawasaki's excellent customer service and explanations of their work.
I hope this thread helps someone with a similar problem one day and saves them money.
The King rides again! :kuda:
oldman
Re: Engine surging
Post by oldman »
It would even be more helpful if we knew what kind of farking bike you ride, as "not worth mentioning" could be a lot of different things.
Re: Engine surging
that'd be a gumby right?
Re: Engine surging
It does a test of those every time you start up, shouldn't it have been throwing up an error code if they were seized?
Re: Engine surging
oldman wrote:It would even be more helpful if we knew what kind of farking bike you ride, as "not worth mentioning" could be a lot of different things.
It's a Ten mate......
so you're right....not worth mentioning
King Nicholas
Re: Engine surging
It is a gumby and no, the Fi light did not come on at any stage.
King Nicholas
Re: Engine surging
Urrrrrrrgh!
The story has taken a new twist, for the worst.
She is doing it again.
Frank (the mechanic) seems to think it is a fuel issue so he is taking it back on Monday.
Soooooooo annoyed, I expected it to be fixed.
I have spent enough money on her.
Any ideas?
browserzx10
Re: Engine surging
Post by browserzx10 »
just pull the secondry butterflies out and get it remapped, could be a faulty fuel pump on its way to a slow death? stopping and starting repeatedly?
I used to have a grip on life but it sliped
Re: Engine surging
yep - pull the secondaries. No more problem !
King Nicholas
Re: Engine surging
Well, I got her back again today and the verdict is...
...it is the side stand spring. It is loose causing the engine to cut out so they have disengaged it and sent me home. If it does not happen again that is it and they will fix it. If it happens again I will spit the dummy.
Re: Engine surging
Well that makes sense, but is a pretty random cause.
Saki
Re: Engine surging
Post by Saki »
i was going to suggest, loose wires at some point ? side stand ? Loose battery terminal ? sounds like a fault where if its on and off its something being connected then coming loose then back on...
Turns out it is
Re: Engine surging
when it happened to my on my 04 zx6r it was a problem with the fuel injection... side stand makes sense though, because it disables the engine, normally you cant push start a bike, but if you are already at speed it would re-start the engine and the backlogged fuel would fire causing it to surge forward...
King Nicholas
Re: Engine surging
It has not cut out and in again since the side stand kill switch has been deactivated so problem found.
I am glad the problem has been found so I can enjoy my baby again.
