Light weight batteries.!
Ed on TrakDaze is selling some lightweight batteries, same as the speedcell ones, if anyones interested.
There about 3 kilos lighter than the stockers.
I have a similar one in my bike (from another supplier) and certainly agree with the weight saving.. Mine may not be so good as it does struggle a little on cold mornings, its fine after that though.. These may be better cells...
http://www.trakdaze.com/phpBB3/viewtopi ... &sk=t&sd=a
RAD02
Re: Light weight batteries.!
Post by RAD02 »
Hey Dave,
You may have cranking issues because
a) your pack may be made using old cells as opposed to new cells
b) your bike is not charging correctly
c) your pack is too small - for race 1000cc with stock charging gear and stock engine 8 cell should be enough (though for colder weather application go 1 size up)
Shelf life on these is 10% overall loss per year (ie leaving it unused - so much better then a matt lead battery)
For total loss use a bigger pack or 1000cc plus use 12 pack for 1400cc ie; ZX14 use 16 cell
I pulled apart my leight weight battery (that I use on my RAD02 1080cc DS racebike) to suss out the make up
It's an 8 cell 4.6Ah 240A 10 sec discharge, 120A continues discharge. Weight is 640gr as opposed to OEM 3.5kg
I also have 12 cell 6.9Ah, 360A CCA for 10 sec with 180A continues
and 16 cell 9.2Ah 480 CCA for 10 sec and 240A continues (basically for ZX14, hi-power race bikes that run total loss)
Made from new A123 LifePo4 cells, and come with connectors.
$200, $275, $340 AUD delivered worldwide.
Yep, the problem with mine is old cells (just like the owner.. :-) ).. its an 8 cell pack but its been around a while, I believe..
It does the job and I would recommend this style of battery..
ZX-10R_04
State: Tasmania
Post by ZX-10R_04 »
Near got me tempted Dave after http://www.carbon-speed.com/prod.htm ripped me off $275 a couple of years ago
04 ZX10R & 08 ZX10R
RAD02
Post by RAD02 »
dave and I have known each other for years, he's kwaka green, I am ducati red, but love giving each other a ribbing, I am happy to do COD for anyone that got done by Carbon Speed ( a few I believe). I am in Brissie and it's on the shelf pick up for locals and express post elsewhere. Sorry to hear you got burnt. Thats why I do all my stuff myself, no middle men, no fuss, of the shelf in the postpack and everyone's good. PM me for phone number and address if you are worried. Cheer Ed ....... 2 cylinders are all you need......hey Dave
Yep, Ed use to have a small amount of taste as he did have a zxr750 but the evil force was stronger..
and yes, 2 cylinders is all a kwaka needs to beat a Duc.. :-)
