ZX14 PCV or TRE
zx14ninja
ZX14 PCV or TRE
Post by zx14ninja »
Hey guys!
If i am getting a PCV fitted an DynoTuning my ZX14 is it necessary to fit a TRE to the bike?
10 ZX14
- Yoshi TRC System.
- PC5.
- K&N FIlter.
- 16T Front Sprocket.
- Flies out.
- Fender elim.
- Wheels done black with red pin striping.
- Anodised billet preload adjusters, bar ends,etc.
- Carbon mirriors.
- Black DB screen.
- Heaps more s#@t...
Dingus
Re: ZX14 PCV or TRE
Post by Dingus »
not necessary at all, but if you plan on getting a TRE down the track I would put it on before getting the PCV mapped.
Re: ZX14 PCV or TRE
TRE is pretty bloody useless anyway :roll:
Dingus
Re: ZX14 PCV or TRE
Post by Dingus »
agreed, I still don't know if mine even does anything at all. The only reason it's still on my bike is because it is spliced into an ECU wire (healtech XTRE).
Someone on the zx-10r.net forums smashed an ivans performance one open and all it was was a 10ohm resistor in an epoxy tube with a connector on the end :shock:
Re: ZX14 PCV or TRE
Dingus wrote:agreed, I still don't know if mine even does anything at all. The only reason it's still on my bike is because it is spliced into an ECU wire (healtech XTRE).
I get a liitle more down low but a lot less up high :shock:
I just don't use it anymore
