GPX 250 loosing power
hay guys ive neva used dis b4 but im in need of sum info i just brought a 89 gpx 250 wen i go to start it, it takes a while to to kick over an wen its warmed up it wont idle properly.......i managed to get it goin an took it 4 a run down da run cum bak turned it off left it for an hour or so came bak out an went to start it it took along time to kick over even wiv da choke, wen i did manage to start it again it was making a snapping, cracking sorta noise an wont idle or anything ................so has an1 got got any ideas thanx so much
Re: GPX 250 loosing power
Change the plugs first & see is that works for starting, as for idle ..... carbs probably need an overhaul
Oh & welcome to KSRC
Brother - good luck with your bike. Welcome aboard.jgord154 wrote:....hay guys ive neva used dis b4 but im in need of sum info ..... an wen ... da run cum bak .. even wiv da choke, wen .... an1 got got any ideas thanx so much....
But for fucks sake - keep the text talk for the iPhone eh ? and learn to spell. This place is not your fully sick bro's phone !!!
thanks
thanx i pulled da carbies off wen i 1st got an gave dem a complete clean an ripped out da spark plugs an dey were sparking great an gave dem a sand down
sorry im still use to typing like that i will do my best to spell normal thank you for the advice
- waynemorgan
- Bike: ZZR600
Welcome aboard - good luck with the bike. There's lots of great advice available here from some knowledgeable people
thanks mate - that is heaps better. I don't want to sound like a cranky old pedantic retard ( even though that is a really accurate descriptionjgord154 wrote:sorry im still use to typing like that i will do my best to spell normal thank you for the advice
OK - about your bike - what Robracer has suggested is a great start. New plugs are mandatory, and you should take the carbs off and give them a really good clean with some pressure-pack Carbie cleaner (from Supercheap) and blow-dry the insides with compressed air. I can almost guarantee that your idle circuits are blocked and gummed up with old fuel deposits. This stuff may need a few rinses to get rid of completely.
Take the fuel hose off the carbie - turn the tap on - and see what sort of fuel-flow you get out of the tap. You want it to be nice and solid, not just 'dribbling' out - this would normally mean a blocked internal filter (inside the tank). You may also need to ensure that the vacumn line from the fuel tap to the inlet manifold is not cracked or split, this can cause problems with fuel flow.
i dont have a airfilter in the bike is that going to make any difference ??????
- Ratmick
- Team Hornet
It's going to make the possibility of having crap in your carbies a bit greater than averagejgord154 wrote:i dont have a airfilter in the bike is that going to make any difference ??????
A clean should sort this out, although if you strip them down completely and don't put them back together properly they will make your life a world of pain...but I guess you have that already.
Mick
will not having a airfilter make the bike run rough????? i cleaned the carbies and it starts but it wont run without the choke
GPZ_Jim
- Bike: GPz500
running with no filter would lean it out eh? would make sense why it won't run w/out the choke.. definately try n source an air filter ASAP
- waynemorgan
- Bike: ZZR600
Sounds more like the pilot circuit in the carb is blocked....
it makes a huge difference. The reason it won't run without the choke, is that it will be running way leaner than it should be without the filters - is the airbox hooked up ?jgord154 wrote:will not having a airfilter make the bike run rough????? i cleaned the carbies and it starts but it wont run without the choke
You really need to ensure that the pilot jets are cleaned out as well, as Wayne M has suggested. Any blockages here will cause rough running at idle.....
yes the airbox is hooked up but i brought the bike in peices and it didnt have an airfilter, but i did buy airfilter foam today
thanx everyone for the advice i will let you all no after the weekend if cleaning the pilot jets and putting on the airfilter has help
One other thing you should also check......take the tops of the carbs, and have a real good close look at the diaphragms that are on the top of each carbie slide. If you spot any small pinholes or rips - the diaphragms are stuffed and you need new ones. Just hold the rubber up so you can see if the sun shines through any tiny holes - if you don't see any, that is a good sign.....
