Latest addition to the 4th......1983 ZX1100A1 (GPz1100)
Anyone who has seen my FB page, knows that there has been something brewing in the 4th Dimension now for a few weeks - not the 1000RX ( more on that shortly) - but another old dunger that was picked up late last year.
I got this bike from ProblemChild (Mick) - he bought it a few years ago, got it semi-sorted, but due to a massive problem with the front forks - he parked it. I promised to buy it off him at some point.......and it found its way here last year.
The front forks were leaking really badly, but due to a seized fork-cap in the l/h forkleg, we could not get the forks apart to sort out the seal. Tried everything too ! :shock: totally frozen solid.
About 2 months ago, I spotted a complete ZX1100 front-end on ebay for $80 !! :kuda: what made this even better, was that it was located just around the corner from my place - literally the next suburb !! Old mate has run a small wrecking business out of his backyard shed for a few years - I have bought some stuff off him several years ago - and couldn't get around there fast enough to grab this complete set of forks & triple clamps, brake calipers and lines.....for $80 !! what a bargain ! :kuda: :kuda:
Because the work on the GPZ1000RX has slowed down - Mick has the wheels and will be doing a number on those with black 2-pack - until these are finished I really can't start on a *rolling* chassis......I had a bit of time to spare and get cracking on this GPz. It needed the front-end changed over - no problem, all that was done a couple of weeks ago....
Biggest other issue was the wiring harness. Whoever had it before Mick, had done a complete butcher job to the OEM harness, and used red wires for ............fucking everything !!! it was a nightmare. Mick did a great job to sort this out to the point where the DFI was working, but had still needed to wire up a fuel-pump switch, as the pump was not working when the ignition and kill switch were 'On'.....as it should.
Over the past few years, I have been picking up the odd spare part for EFI / DFI for these old fuel-injected Zeds (including stuff for the Black Pearl.) - So I grabbed a complete wiring harness for this model out of the electrical rack ;) , and replaced the entire wiring loom. This has made the entire job way easier.....as you would expect.
Before the DFI was fitted, I decided to make sure the bike was going to work OK first. Last year, I had taken the head off with the intention of using it as a spare for the race-bike........but when we took the head off - it was very dissapointing to find that someone in the past had swapped the OEM head ( the good one with high-compression and better valve angle)- for a stock GPz1100B1 head - these heads have the stock hemi combustion chamber and standard Z valve angle.....they work, just not as good as the ZX1100 heads.........so I never bothered using this head ( or fitting it back onto the bike....) until last weekend.
The bike fired up just fine with a new battery and the race-bike 33mm smoothbore Mikunis. I had intended to run it with these carbies - but they are just not practical for extended street use.....so I decided to have a punt at re-fitting the OEM fuel-injection..... :shock:
well after some initial issues - the fuel-pump was only working intermittently, and also the starter-motor only seemed to work every now and then - these were traced to just dirty contacts in the connector plugs....old and very crusty ...the DFI is all up and working well, the bike starts first time at the moment, and all the normal things - blinkers, horn etc - all work OK.
I am waiting on a replacement headlight bucket, and still have some further tidying-up of the bodywork - but basically, its all there, all together, and working.......done several laps around the backyard, and so far so good.
The Corbin seat was a bit of a find - thanks to GPz750Turbo from another forum. It fits perfectly, and is brand-new old stock from the US. Looks a lot better than the OEM seat.....
So there you go - unfortunately too late for Gingers Creek this year - which shits me no end, as it would have been great to take it for a thrash up the Ox :lol: - but once rego has been sorted, this bike will be nice to belt around on for a few months during spring and over summer......
waynemorgan
Re: Laterst addition to the 4th......1983 ZX1100A1 (GPz1100)
Post by waynemorgan »
That looks great Gos - well done on the forks for it too :)
Gotta love the GPZ :D
dub
Re: Latest addition to the 4th......1983 ZX1100A1 (GPz1100)
Post by dub »
Looks tops mate :kuda:
2004 Z1000
1982 GPz750
Hey Gos, great to see it up and running finally!! I knew you would get around to it soon enough! I bet Mick is cursing giving it to you now it's a runner!! :lol:
Now, when will that be elligible for histerical racing??? ;)
cheers all - Dub it is a bit like Son of Eddie.....sort-of.... ;)
Marty - Mick is happy to see it up and running, especially with the DFI fitted. This gets ditched far too often on these old dungers, so I am determined to do whatever is needed to keep all that part of the bike as stock as possible.......It is eligible for P6 racing now (1983-1990) but would be way out of its depth in that class.....just too long in the wheelbase......but great for the odd long strop in the bush !!!
ivan
Post by ivan »
nice beast and i like that seat :kuda:
You have serious problems gos, get help :lol:
Nice work Gos. Looks great
Mel
Post by Mel »
Looks awesome Gos :D
2010 ZX6R
1997 ZX7R
I ride like a girl...
bonester
Post by bonester »
Noice mate. You are going to have to build extensions for the 4th soon! :D
bishboy
Post by bishboy »
Looking the goods 8)
I thought about getting something similar and doing some mods to end up with something like this, although I'm not sure what the mods are, except I think its a ZX9 seat..
84 KX250
79 KX/KLX 250 evo project
YZ465 latest project
...good stuff Gos :)
the kid
Post by the kid »
Thats looking great Gos . Good work .
chimp
Post by chimp »
Congrats Gos! as you say " it is the ducks guts" looks fantastic, just need to work on ya grass mate, dynamic lifter instead of 5w30 might be the go :P
Only a Motorcyclist knows why a dog rides with his head out the car window
Bikes:Zrx1200r Z650 Gpz750r Cbr1000f & Postie!
Tops Gos, very tidy :kuda:
