Upside down eccentric chain adjuster
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
Hello fellow REX owners ... Newbie Rex here ;)
Got an easy one for you ... hopefully . .
As my adjusters have been inverted to lift the tail up a tad, the markers are now no where near the indicator . .
Im assuming there is a quick n easy way to get the rim straight without pulling the old string out . . .????? . ..
2004 ZRX1200R
And it was good
Re: Upside down eccentric chain adjuster
Richo wrote:Hello fellow REX owners ... Newbie Rex here ;)
You set that when you put the rim in before you tighten the axle ;) , then you move one side and they both move at the same time ;) :kuda:
So you can use the adjusters to set the spacing, then invert it when putting the back wheel back on. HTH
Or you just get Ohlins shocks and make them longer - lets you leave the axle in the intended position :twisted:
when I had my rex I just put a thin line on the arm' with a permanent marker 8)
professional :lol:
ohh yeah and it's not fire proof !! :lol:
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
Thanks Phil ... was too easy ;)
2004 ZRX1200R
And it was good
oldman
Post by oldman »
Get about a 1 meter long piece of 90 degree angle aluminum and place it tightly fore and aft along the chain and measure each end of the rear wheel, (front and back) until it is even. Works for me as the adjustment marks are always a little off anyway. Jim Beam helps.
