Red key Myth
Red key Myth
Just clearing up that eternal Kawasaki Myth. YOU CAN get black keys copied from another black key. ;)
Granted only specialist locksmiths can do this but, it is possible.
I only had 1 black key for the new race bike but now I have 3 :kuda:
$165 each including key, cutting and recoding.
Re: Red key Myth
Got any pointers for anyone who is in the same unfortunate position?
timmyrocks
Re: Red key Myth
Post by timmyrocks »
cool, how do you go about it if you loose one of the black keys, dont you need the red key to change the keys over?
or are the codes in all your black keys the same, so to your ecu all you keys are the one???
Team Crash "09"
WR125 2004 Husqvarna :P
Re: Red key Myth
Doing it the "correct" way you would have a set of available "slots" in the ecu for a fixed number of key codes (i think it's 12 or so). If you get another key added you utilise another "slot" within the ecu. Once you fill it up you have to clear out the old slots and start adding in keys again.
Doing it this way your merely recoding a new key to replicate the code in an existing key that you have and you don't have to worryt about availability of slots within the ecu..
Re: Red key Myth
correct.
your simply coding a blank to be mirror image of the original. All works fine
No tips. Just try and find a locksmith that has the expensive software that can code the duplicate ;)
Re: Red key Myth
What I should say is that if needed I have contact details for a locksmith that can do this obviously.
Re: Red key Myth
revival
Re: Red key Myth
Blurr wrote:Just clearing up that eternal Kawasaki Myth. YOU CAN get black keys copied from another black key. ;)
you use a key on a racebike..???? :?
Re: Red key Myth
yep. FX1000 needs to run stock ecu and wiring. Along with stock key fuel caps ;)
same as superstock
Re: Red key Myth
and you cant "hotwire" without an immobiliser key. Smitty.
only option is racekit ecu, as Russ said, not allowed on FX
cloudnine9
Re: Red key Myth
Post by cloudnine9 »
ok.
thats great.
do you know of any locksmiths in queensland that can do it I'm on the northern gold coast and have similar problem just bought a 06 636 that has only got 1 key ,
a black one.
a spare would be a good idea.
cheers Cloud 9
Re: Red key Myth
Yellowpages.com.au ;)
cloudnine9
Re: Red key Myth
whats the chances of stuffing the only funtioning key in the process??
cloud 9
