Have replaced ecu & wiring harness with an american setup but still no fuel pump or servo motor
any ideas to get the girl going? cheers Bwz1a
07zx10 wiring ??
Re: 07zx10 wiring ??
kill switch?
in gear?
clutch switch? sidestand switch?
in gear?
Australian harness ?? (maybe the US stuff has some pollution control that we don't, the ECU is not sensing it, so no start ?)
bwz1a
Thanks for the input ,
I found the side stand connection & bridged them out & it started
the servo mtr worked as you accellerated so i thought it was sorted!
I turned it off after running it for 5 minutes to tape up unused wires & sure enough it wont start again
HELP !
HELP !
- greenman43
Definitely nothing to do with the clutch cut-out switch that Wattie mentioned, Gary ?
BTW, are you going to be in on Saturday morning ? I can possibly get over (pretty early) and drop the wheel off.
Brian
Brian
bwz1a
Getting hold of a workshop manual for the fault codes to sort iy !!!
Thanks Brian see you sat
cheers Gary
cheers Gary
