hi everyone i noticed my bike was leaking fuel from the carby yesterday so i pulled the carby apart an saw the gaskets need to be replaced
so i put some gasket adhesive on it just for the time being after putting every back together i went for a ride an it started surging.
im not sure what the problem could be? any help would be great miss riding her already haha
Check to make sure you sealed everything up properly. If the only thing you did was to remove the carbs, then it is most likely to be something to do with that. Fuel hose Kinked maybe? Inlet rubbers not seated properly??? Dodgy sealer repair not thorough??
