Stalling When goes back to low rev's
el_capitan82
Post by el_capitan82 »
Hi how are you I am new to the site so hi to all and I hope you can help me.
I have just got a 96 zx7r as I have been on Honda’s a lot so I do not know too much about Kawasaki’s witch I a loving riding now,
I have had this bike serviced and the shims done by a mech just so I know it was checked all over for the first service.
But the issue that I have is, after having it at high rev's and then I slow down to stop the bike down and hence so do the revs it stalls on me I think they have modified the throttle to a quick action release I think that what it is call if any one has any ideas would be great to hear back from you.
Thanks Nate
Re: Stalling When goes back to low rev's
You can try the Idle adjustment, it will be a small cable with a knob on the end coming off the carbies, adjust to 1200 revs when hot & she shouldn't stall anymore.... Oh & welcome to KSRC :D
el_capitan82
So u dont think it could be anything eles coz of that quick release throttle, i can smell petral when is stalls too if that helps
If there is freeplay in the throttle then that is not your problem, there should be a little bit of play in the cable before it takes up & the cable pulls.
The petrol smell is probably a build up of fuel fumes from the airbox ;)
el_capitan82
thanks will give it a go
damotm
Bike: GPz750
Post by damotm »
sounds like its flooding man, my gpz used to do this when the carbs were dirty
Honda XR75 :), KX80 D2, GPZ1100 B1, Aprilia RS125, Honda VT750, Restored GPz 750, Harley FXDX, Harley Street Bob
el_capitan82
had the carbs done when tuned ,was ok today but did try and stall again, mate said maybe stick flots
craig
Post by craig »
see the mechanic whose just done all the work on your bike.............ask him "how come?"
freestyler
Post by freestyler »
could be a vacuum leak, check any hoses coming off the carbs, make sure they go somewhere or are blocked up
1996 ZX6R
