Whites Racing Products tomorrow night
- Glen
Is anyone heading out tomorrow night? I'm gonna go and get my tyres fitted.
Re: Whites Racing Products tomorrow night
hmmm sounds like s plan, but i cant get there
- Blurr
yeah does one want to find out if he has any of the good bridgestones out the back
- Wardy
I'm going to swap mine over and get a set put on rims.
06' zx6r limited edition
swap to what?Wardy wrote:I'm going to swap mine over and get a set put on rims.
Wonder if he's got 016's, Tim needs a new front for his new ZXR.............
- Wardy
pilot roads.. Nah. A softercompound slick. A source has found the hard compound to be too hard.Wattie wrote:swap to what?Wardy wrote:I'm going to swap mine over and get a set put on rims.
- Kev
I was thinking of heading out there to grab some brake pads. I had this rather unpleasant grinding noise coming from the front end yesterday and then realised hit metal.
- Wardy
Well I ended up sticking with the hard bridegstone slicks, shouldn't have the problem others have had as the 6 doesn't have the power of the 10 obviously. Also the 180 is a different construction to the 190 so pressures etc will also be different. Craig mentioned some guys are running the 190 as low as 18psi cold. The 180 is around the 27psi mark. Hopefully it's not wet on the weekend and I actually get to try them out.
Dont get the gold fern ones, mine were binding like barstards, changed pads the other day & problem solved... oh & I had done a full service on the calipers (cleaned the pistons & greased) to no avail, I will never buy another set of those againkevZX9B2 wrote:I was thinking of heading out there to grab some brake pads. I had this rather unpleasant grinding noise coming from the front end yesterday and then realised hit metal.
- MadKaw
- Administrator
Thats odd, I've used plenty of the Gold Fren pads with no problems...robracer wrote:Dont get the gold fern ones, mine were binding like barstards, changed pads the other day & problem solved... oh & I had done a full service on the calipers (cleaned the pistons & greased) to no avail, I will never buy another set of those againkevZX9B2 wrote:I was thinking of heading out there to grab some brake pads. I had this rather unpleasant grinding noise coming from the front end yesterday and then realised hit metal.
Usually filling the bases a little and chamfering the leading edge of the pads can stop binding and get quicker release, if its a problem (I've never had too but occasionally chamfer the pads if I remember.)
I could hardley turn the front wheel on the stands at one stage, so a slight chamfer would not have worked
......... anyway as stated changed to another brand & problem solved so I am happy
yes, Im not impressed with mine atm and am on the lookout for replacements...
- Kev
Thanks for the heads up re the pads. I couldn't hang around last night so never ended up getting a set. I know this probably sounds like a stupid question, is that the brand he stocks?
- badinov
Yes that is what he stocks, Gold Fren .kevZX9B2 wrote:Thanks for the heads up re the pads. I couldn't hang around last night so never ended up getting a set. I know this probably sounds like a stupid question, is that the brand he stocks?
I have them in my ZX6 and have had no problems, whatsoever!
Will use them again next time too ( although haven't tried HH's yet ?)
