Dollars
themaloryman
Bike: Ninja 250
Dollars
Post by themaloryman »
Hi,
anybody know what I'm likely to be looking at to replace the front faring and windscreen on a 1995 ZXR250C? Also, does anyone know if you can even get specific parts for these still, and if so, where?
It fell over. :(
Cheers.
Two wheels good, four wheels bad.
Re: Dollars
Just search for second hand parts through findapart.com.au.
Much cheaper and with a 250 almost everyone expects them to have been dropped so resprays arent an issue.
themaloryman
Bike: Ninja 250
Re: Dollars
Thanks Blurr.
Wardy
Re: Dollars
Post by Wardy »
You could also look into repairing. Plastic weld then a respray. Or zip tie and tape, coz it'll probably happen again.
06' zx6r limited edition
Re: Dollars
Wardy wrote:........ Or zip tie and tape, coz it'll probably happen again.
:lol: :lol: talk about confidence inspiring Wardy :P
Re: Dollars
I call it realistic. :D
craig
Re: Dollars
Post by craig »
yep go with the advice above patch scratch paint cheaply save for next bike ...there are kits to upgrade the look ...$ XXXXXXXX,00 but ebay is best friend and the top fairing comes up rarely screen available ex hong kong about $90.00 possibly local but have looked consistently and "no see" try liverpool wreckers nsw...southern cross i think melbourne and .....................SUMOTO for over inflated prices and sh..y service
gpxpunk
Re: Dollars
Post by gpxpunk »
Wardy wrote:You could also look into repairing. Plastic weld then a respray. Or zip tie and tape, coz it'll probably happen again.
plastic wwelding is the way to go aslong as you know what your doing. Alot cheaper if you do it yourself. but practice first, it helps.
1987 GPX250R. memories
2002 ZX7R . sold!!!!
themaloryman
Bike: Ninja 250
Re: Dollars
gpxpunk wrote:...aslong as you know what your doing.
Now that is the relevant point!
Thanks for the tips. The other thing I talked about with a friend was cutting it back along the break (which is at the top) and smoothing it out to giving it a 'custom' look.
Which would be great until I needed to fit a new screen... :)
