can any one explain the set up of shockers onthe zzr 250?
mines gone and need to be replaced but not sure how it all is under there. I'd like a bit more info so i don tloook like a dumb female when i go to the mechanics.
the shock is fine, all the lwr link arms need rebushing.
Mj is basicaly after a second opinion B4 i attack it After all i ride a honda and we all know they last forever !!
i'll just hide over there now >>>>>>>>>>>>>>>>>>>>>>>>>>
G'day, if you can get a new shock you can replace it yourself, its piss easy. Take off the back wheel, remove the bottom bolt on the tie rod arms(swing arm to rocker) and swing clear, let swing arm down, unbolt/remove shock. Reverse the steps to re-install. Take note of which holes on the rocker the shock and tie rods go into. Good luck, not that you'll need it.
2001 ZZR250
2x KR250s (anyone wanna buy em' ?)
150cc 4stroke TRICK Bucket (2005-SBL's Ams champion & Most Outstanding Rider)
500cc and 650cc TRICK Supermonos (2006-Bears F5 9th,only did 2 rounds before I f#%ked up)
if you have an ebay account, look for a seller named proven_suspension. These guys are the people that bought out all the koni shock gear when they stopped making bike stuff (i think) and sell it under the ikon label instead. They have ebay auctions for heaps of stuff (dirt cheap if you find them at the right time too, i got my shock for $120, rrp for 3x that at least!) (or look at http://www.proven.com.au for prices.)
