drilling a threaded hole into a triple clamp
- matchan
Yes, you read that right!
I need a threaded hole in my lower triple clamp, (track bike) I have no idea how to achieve this! Obviously drilling the hole is reasonably easy, but how to get it threaded to a particular size?
Matt
Matt
- Six Addict
- Pinchy
- Bike: Ducati
Re: drilling a threaded hole into a triple clamp
Drill it then tap it? Isn't that what it's called?
Knowing my record it's prolly not
- 6maniac
- Bike: Z750
Matt - what size bolt is it ?
- matchan
damn, caught out, I think it's an M4 Ron, but I've not measured it yet.
- 6maniac
- Bike: Z750
Example - 6mm bolt = 5mm drilled hole, then a 6mm tap to thread the hole.
- Ratmick
- Team Hornet
Obtain a Drill and Tapping chart and purchase the right size drill bit and tap would be the easiest method.
http://en.wikipedia.org/wiki/Tap_and_die
Tapping a hole in something and getting it right the first time may be a big ask, especially if the item you're trying it on is expensive or hard to remove. Blind holes are also harder than holes that are tapped right through. In both cases it may be a good idea to test your technique on some offcuts of alloy/whatever. If you have a mate/parent that has done it before it may also be useful to get them to show you how it's done.
If not there are plenty of 'how-to' guides on the net, so have a search on Google or Youtube. It's not difficult, although doing the job on something that is expensive, you only have one of, or something that belongs to someone else is a bit stressful
A few tips:
* Take it slowly.
* Use the right size tap for the drill and vice versa drill for tap.
* Use lubricant and reverse the threading every quarter to half a turn to break the swarf off.
HTH, Mick
A few tips:
* Take it slowly.
HTH, Mick
- 6maniac
- Bike: Z750
- 6maniac
- Bike: Z750
Or .... bring it up to Madkaw's and let the Team loose on it !!
- matchan
thanks Guys, at least I know what it's called now
- MrWasabi
- Team Kuda
I'll swap you my trees Matt, mine already have 2 holes drilled out
- badinov
Matt, I have a tap & die set if you need to borrow one !
You also need to check the "pitch" of the thread
- seiko1
- Bike: ZX14R
DO NOT USE OIL AS LUBE ON ALUMINIUM ALLOY!
Lube to be used on alloy must be preferably kero based as std oil has the opposite effect of lubricant.
8 yr's at Alcan taught me something
- matchan
Thanks Bruce, I'll let you know by PM once I'm ready.badinov wrote:Matt, I have a tap & die set if you need to borrow one !
Thanks to all for the advice.
Matt
