So far we've checked all the wiring to make sure all the connections were/are clean & secure, all the way from the battery to each light bulb. We've heard that poor earthing could also cause the same problem, each bulb has been metered to make sure each ground is actually ground, they tested ok, so we grounded each of these to make sure anyway. We used the tail light to test, so by disconnecting different things (at the plugs) we ruled out the dash lights & head light. By disconnecting the key switch plug & linking the 6V power rail at the plug we ruled this out too, & doing the same for the indicator/dimmer switch assembly we ruled out any poor connections. With ALL but the necessary disconnected, the tail light still dims when the indicator flashes.
We decided to try & rule out the bike's wiring all together by crudely wiring up two 6V 17W globes from the indicators straight to the battery (with all but the necessary disconnected) & manually turning on & off the 2 indicator lights by hand (while the bike was running & not running) we could see the tail light still dimming.
Using the voltmeter we measured the new battery while the bike was running & it measured about 7.5VDC, while not running it measured 6.2V.
My hubby is thinking that the 6V system seems to just do it, is this normal?
Thanks to any answerers in advance
p.s I'm not the technical one, hubby is, he'll be the one implementing any answers!
