gpx 250 caliper
All GPx and GPz Models
blackkwakka
Bike: GPx250
gpx 250 caliper
Post by blackkwakka »
does anyone have a front left caliper for a twin disk gpx 250 they want to sell must be in good condition, mine is sezied and crapped which makes brakin not very good
timmyrocks
Re: gpx 250 caliper
Post by timmyrocks »
if you dont have any luck mate, spray some WD40 around the pistons, and try and pump them out (this will be fairly messy) or blow them out with compressed air, watch out they will fly out and give the pistons a clean.
or first off take it off the disk and pump the lever, see which piston moves as sometime only 1 moves, jam that piston with a screwdriver or bit of wood to stop it from moving and pump again, hopefully this frees them up and you should be able to get in there and give the piston a clean without making a mess with brake fluid :kuda: :kuda:
hope this helps or just try findapart.com
Team Crash "09"
WR125 2004 Husqvarna :P
gpxpunk
Re: gpx 250 caliper
Post by gpxpunk »
damn thats going to be hard to find. sorry but mine are staying on the bike. lol i have a standard single one haha but thats no help. one of the guys checked out my bike and said that the calipers are the same as the zxr250 but i dont know if thats correct.
1987 GPX250R. memories
2002 ZX7R . sold!!!!
blackkwakka
Bike: GPx250
Re: gpx 250 caliper
yea i will pull it apart when i get my car regod again i might have to just get the caliper reconditioned but as i ride it to work everyday its a bit hard atm to take it off the road. it all started when i got the tyres changed when i put the wheels back on i had hardly any front brakes so i bled them, a few small bubbles came out of the right side then the lever was hard as the pads looks pretty bad but when you pull the lever u can see the right caliper compress and let go but the left side dosnt move. i dont think its so much the pistons that are seized but the bottom slider dosnt seem to move in and out with the force of the fluid i might have to take it off completly and pull it apart how do you get the brake pad off that goes onto the sliders
gpxpunk
Re: gpx 250 caliper
Post by gpxpunk »
they should just pull off.
you will need to compress the sliders back as far as you can. Then take one end off at a time. They can be trickie sometimes. Also I had bleeding issues when i installed the twins. took me a few hours at first. then a week later when they settled i bleed them again. I would give them a bloody good clean and degresses and see were you go from there.
blackkwakka
Bike: GPx250
Re: gpx 250 caliper
when you bleed them can u you leave the cap off, i left the cap off in my ute ended up with a brake fluid fountain all over the car not fun
gpxpunk
Re: gpx 250 caliper
Post by gpxpunk »
blackkwakka wrote:when you bleed them can u you leave the cap off, i left the cap off in my ute ended up with a brake fluid fountain all over the car not fun
lol i did this once and now i have paint missing from the fairings. lol that stuff doesnt mix. just keep a eye on your fluids and make sure you dont pump through to much.
Its always a bitch to bleed these things, the thing that helps me, is a clear hose that attachs over the nipple. You will be able to keep the fluid away from wheels and fairings and you will also be able to see how much air is in the lines and also doesnt allow to let air back in.
