Chain cleaning?
Nafz750
Chain cleaning?
Post by Nafz750 »
So sunday will be zed cleaning day, my chain and sprocket are quite gunky from chain lube. Is the degreaser in the spraycans ok to use? Will it destroy the o rings in the chain? I thought it wouldnt but wanted to double check before I do anything and have to buy a new chain. I know petrol is a no go, or is it? Any other good ways of cleaning them?
*'05 z750 - micron pipe, bodymods, custom paint, now its GREEN
Re: Chain cleaning?
Kero. I only know from asking the same question, and yes apparently degreaser is bad for o-rings. :D
Nafz750
Re: Chain cleaning?
Post by Nafz750 »
Awesome, cheers for the quick reply, did you dilute the kero or straight from the bottle? Maybe I should search this topic haha, its too early to function...
Lone Wolf
Re: Chain cleaning?
Post by Lone Wolf »
Kero works best
kaneg
KSRC SPONSOR
KSRC SPONSOR
Re: Chain cleaning?
Post by kaneg »
Kero straight up, no need to dilute :kuda:
Re: Chain cleaning?
I always use WD40 or equivalent and a toothbrush.
Spray blows most of the shit off too, saving you scrubbing time :kuda:
Nafz750
Re: Chain cleaning?
Post by Nafz750 »
What a difference, I couldnt wait so got in before our visitors arrived and cleaned the grime off, man it was terrible, cant believe I left it for so long :( just waiting for everything to dry and ill give it a good once over, thanks for the kero suggestion :D
Re: Chain cleaning?
Kero, paint brush, leave to dry and relube.
I tend to Kero the chain, wash the bike, let it all dry then relube. WD40 is very good at removing lube splatter, simply spray WD40 onto a cloth and wipe the lube splatter off. Great for under seat areas, rims, chain guards, huggers and under seat exhausts.
