KLEEN/Pair mod ??
ezydeek
KLEEN/Pair mod ??
Post by ezydeek »
can someone explain what this mod actually do?
DONG 1. v & n; TO hit or punch "Watch it, or I'll DONG ya!" 2. n: A penis "Good lord, my dong is huge!" also slang for 'DILDO' or DOUBLE-DONG
DONGA. Ratherly larger than a dong
Re: KLEEN/Pair mod ??
stops the popping and small backfires when you shut offf the throttle.
wont reall make a difference unless you have a slip on pipe or full system. 8)
ezydeek
Post by ezydeek »
reading other forums from the US
they say u need to do this if have a pc3 to get better reading
is this true??
well apparently not. the Kleen air only opens up to let the fresh air in once the throttle is closed. so i dont think it matters.
i stuck a small garden type tap in my one on the Z, and just closed it off. i reall dont think it affects it on the dyno.
