Disc Grinding
Dustproof
Disc Grinding
Post by Dustproof »
Hi all,
I am looking for someone who can grind all 3 disc's on my KZ650D2 SR, if possible around the Hornsby Area. My rotors have some ripples and new pads just don't like gripping them, new ones are a bit expensive and it is a bit hard trying to get used ones.
Any help would be most appreciated. 8)
Thanks
Noel
Slow and wobbly
Re: Disc Grinding
Post by Slow and wobbly »
Slow and wobbly
Re: Disc Grinding
Re: Disc Grinding
Noel - you could also try some of your local brake & clutch specialists - anyone who machines flywheels will also be able to do this job. Some of them may get a bit narky about grinding bike discs, especially if you get below the minimum thickness ( its 4.5mm or 5mm on those old discs as I recall...) - just tell them its a vintage bike that is going in shows, and is hardly ever ridden !! :kuda: Thats worked for me before.....as long as you don't go under 4mm on these discs, they will be fine.
If you end up needing to source some disc rotors - for old stock ones, try Penrith Wreckers. These guys specialise in pre-85 stuff.
Dustproof
Re: Disc Grinding
Post by Dustproof »
Thanks Guy's, I will see what can do. I haven't measured the Rotors as yet but thanks for the tip for a new-old set. After this has been done I will go the Braided line route even though I am trying to keep the bike a period machine I will go down the safety track.
Thanks
Noel
Slow and wobbly
Re: Disc Grinding
Grahams Grinding
Browns Plains
QLD 4118
07 32000644
Advertising in AMT
"We specialise in Disc Straightening, Re-grinding and de-lipping
We straighten, Regrind and re-rivet Floating discs
Road bikes from $130"
No website but the number is above and it couldn't hurt to make the call.
No matter what the outcome could you please post a response regarding this business.
Re: Disc Grinding
Yes, that would be great. Its not often you find anywhere that advertises disc grinding....
Dustproof - If you really want to keep the 'period' look, just take the stock rubber lines down to any brake shop - most of them will be tooled up to make brake lines. If you get them replaced with 'brand-new' rubber lines, then the braking performance will be much improved, almost to the level of braided lines.
