Can I pop rivet my yoshi slipon (zx6 06')
- Wardy
Thinking about pop riveting some mounting brackets onto my yoshi slipon instead of using the mounting strap (which I haven't got yet, Mladins closed til July). Won't be welding it on, because I guarantee I would blow a hole in it.
Can anyone see any problems with doing this?
thanks
thanks
06' zx6r limited edition
Re: Can I pop rivet my yoshi slipon (zx6 06')
Use the strap dude
- Frank
Wardy I might have a strip of SS you can use to make a strap, thats what we did on a friends bike.
GO THE BLUES
Life time member of PETA:-
Member of SRT
1998 Kawasaki ZX9R Track Bike
2014 Nissan Navara
Member of SRT
2014 Nissan Navara
- Wardy
I've got some stainless lying around so I have another stupid question for ya. Do I need the rubber to go under the strap. If yes where can I get some from. I wouldn't usually care but it's a new and shiny.
- timmyrocks
i can get some 1mm or 3mm rubber sheet from work
if ya want i will get some for ya and gie it to yar
Team Crash "09"
WR125 2004 Husqvarna
Team Crash "09"
Warning !!!!
if the rubber is thicker than 1mm you will squash and dent your can when you tighten the strap !!!! It needs to be super thin !!!! (I speak from experience !
Also, I dont think the sleeve will be strong enoght to support the rivet mount in the middle of the pipe either..
- Wardy
Thanks guys. Will see what I can find over the weekend and get back to you if I still need the strap or rubber.
- Wardy
Well I've bodgied it up to get me through until Mladins open in July. Used some exhaust heat wrap to protect can and then used some stainless steel zip ties.
- Saki
- State: Western Australia
PICSORDIDNTHAPPENWardy wrote:Well I've bodgied it up to get me through until Mladins open in July. Used some exhaust heat wrap to protect can and then used some stainless steel zip ties.
- ZX-10R_04
- State: Tasmania
just cut an old pushbike tube up for the rubber under the strap
04 ZX10R & 08 ZX10R
04 ZX10R & 08 ZX10R
um I think that would meltZX-10R_04 wrote:just cut an old pushbike tube up for the rubber under the strap
- Frank
Hasn't melted the one on my track bike yet.robracer wrote:um I think that would meltZX-10R_04 wrote:just cut an old pushbike tube up for the rubber under the strap
GO THE BLUES
Member of SRT
2014 Nissan Navara
Member of SRT
2014 Nissan Navara
pushbike tube is a bit thin......MX bike tube is better. I reckon the pushie tube rubber would melt on a long road ride, but is fine for short blasts on the track....
