Quick Question, I have a 99 ZZR1100 with 180 rear and 120 front tyre, wondering what tyre pressures I should be running.
Currently have around 36 psi - is that OK?
Tyre Pressures ZZR1100
- Six Addict
- Pinchy
- Bike: Ducati
Re: Tyre Pressures ZZR1100
the hoff will be along shortly...
in the meantime what tyres have u got on the big girl???
if u wanted to you could probably bump the rear up to 38-40 to increase tire life...
HTH
HTH
Head_Mechanic
- Bike: ZZR1100
- State: Tasmania
42 psi all round works well on my ZZR1100 with or with out a pillion . Any less and the side walls may start to flex. Give it a run and see how you get on.MattyB wrote:Quick Question, I have a 99 ZZR1100 with 180 rear and 120 front tyre, wondering what tyre pressures I should be running.
id suggest around 37 front and 41 rear, but it does depend what tyre you are running
- seiko1
- Bike: ZX14R
I've always run 40 psi front/rear.
But my suspension is to hard JONNO
- large
- Bike: ZZR1100
I run 38 up front, 40 rear may go to 42 on the rear if I've got a lot of luggage or a pillion.
Thanks Guys, up front I have a Battlax BT54-F 120/70 ZR and on the rear I have a Michelin Pilot Road 180/55 ZR 17
These were on it when I bought it, and will probably change when they get down a bit.
Matt
Matt
- seiko1
- Bike: ZX14R
I have a Battlax up front too.
She refuses to sit in the back with the kid's
