1st, I have carried out the following since:
Emptied and cleaned the fuel tank, drained both carbies a couple of times, used a bottle of carbie cleaner during the course of three tanks, without much change to the problem. Do you think my only other option is, remove the carbs and clean the jets with a fine wire.
2nd, Today as I was cruising at 60Ks and felt the bike jolting slightly, what could this indicate?
3rd, Some time ago I had the bike on the centre stand to check the chain and I noticed the chain is relatively loose but within limits however, when I rotate the wheel a full turn and inspect the chain again, the chain is tighter. The rear sprocket is in line with the wheel and the teeth are ok. I have been lubricating the chain and cleaning it regularly but for some reason the chain links are ok for a length and tight for another length, can you suggest any reason for this, and what is the best cause of action?
I have considered replacing the chain and sprockets, front and back, would this be the answer, and do you think this may be also responsible for the jolting or cause any other issues that are not yet obvious at this stage?
I have been quoted $300+ for the chain and sprocket replacements and $100+ for the rear brake pad replacement. I was also thinking would it be in my best interest to change the dampers in the wheel axle area, and do you think the quote is a fair price?
Bike history:
93 Model, 18,200 kms, purchased last July 08, I have clocked 5k kms since then. The bike was not ridden for about 8 months before I bought it.
Cheers.
