Removing Radiator Fan '96 ZX6
Mike
Post by Mike »
Hi all,
Currently building my '96 ZX6 track bike.
I have a quick question for the mech heads... Can I remove the radiator fan permanently? Seeing its a track only bike it wont be sitting in traffic etc etc. So is the fan in integral bike of the bikes cooling system or like my old bike, it only does anything when the bike is stationary while running and not getting any air flow, in which case I could take it off :kuda:
Thanks,
Mike.
Join Team Ghetto Racing
timmyrocks
Re: Removing Radiator Fan '96 ZX6
Post by timmyrocks »
i removed the radiator fan off my vfr400 race bike, gets a bit hot on a warm day, but its ok (just need a better radiator cap as mine shit :lol: )but in sayin that some of the guys come into the pits and their fans goin,,, i think most the guys with newer bikes leave them on :kuda:
Team Crash "09"
WR125 2004 Husqvarna :P
2ndclasscitizen
Post by 2ndclasscitizen »
Are you really going to get mucb benefit from taking it off?
timmyrocks
the benefit on my bike is i dont have to dismount the lower radiator to do oil and filter and plug change, also some guys reckon air flow to you engine is better without the fan and shroud in place so your engine gets more air :?
either way its much for muchness :kuda:
Team Crash "09"
ducati_paul
Post by ducati_paul »
kawasaki250 wrote:the benefit on my bike is i dont have to dismount the lower radiator to do oil and filter and plug change, also some guys reckon air flow to you engine is better without the fan and shroud in place so your engine gets more air :?
But it's Water Cooled not Air Cooled! MY bike often omes into the Pits after a workout with the fan working overtime, but then most of my radiator fins are bent! :roll:
timmyrocks
yer it is water cooled, but that doesnt mean that air wont cool it down, maby not as effective as a fan, though if your cooling system is good the air coming through the radiator should keep it cool enough, my bike only relieves coolant to overflow when im sitting in the pits after a session when its idling, so i guess radiator fans would stop that, but out on the track its fine sits right on half even on the hot days, so im happy :kuda:
Team Crash "09"
Mike
Post by Mike »
2ndclasscitizen wrote:Are you really going to get mucb benefit from taking it off?
Stripping everything I dont need.
If I dont need this to stop my bike overheating then it will come off. Just trying to find out if it can be done without causing major overheating problems. :D
Goanna
Post by Goanna »
My wife and I both have ZX6Rs as track bike's '95 & '96 and both have the fans removed.
Neither of us have over heating problems.
If your bike over heats at the track you got other problems going on rather than not having a fan.
Unless you sit in pit lane all day with the engine running.
Mike
Post by Mike »
Goanna wrote:My wife and I both have ZX6Rs as track bike's '95 & '96 and both have the fans removed.
Awesome, Thanks for the reply. :kuda:
I didn't have one on my 98 zx9r..
Never ran hot..
and it still doesn't with Frank on it...
Didn't have one on my 93 zxr750r either...
I still have mine fitted and operable. Only cause I have changed anything since it was a SS bike and they needed them back then to be legal. Other than that, it could come off. But it's just more work I don;t want to do! :oops:
