I'm curious as to what the symptoms are of a failed head stem bearing?
I was riding on the weekend after having the bike stored for 6 weeks and whenever I braked on a slight angle, I was experiencing slight brake shudder through the bars/ brake lever.
I have checked the tension of the caliper bolts, handlebar mounts, top yoke bolt, fork bolts, rotor glazing, pad thickness and even checked wheel bearing play.
I doubt my 1000km old front Pilot Power has flat spotted from being stored, but could be a culprit?
I do not have the facilities to lift the front end off the ground & am curious if anyone could offer suggestions as to what might be the issue?
Cheers.
Daz.
