so finally i decided to do what the salesman told me to do (keep below 6000rpm) but occasionally it goes to 8000rpm. what should i do in the break-in period?
Thanks in advance
if u need lesons in this, im available...Ride it like you stole it![]()
dave#3 wrote:Ride it like you stole it
Seriously, don't rev the daylights out of it (try to keep it below 8K rpm) and don't keep it at constant revs for a long period. Once it gets to 1000kms change the oil and then just ride it.
, mine says don't rev above 4000rpm but anyway, i'm still in my "breaking in" period too and i've been mainly sticking under 4000rpm but i have to vary it a fair bit because of the area i live in (some hills, funny corners etc). basically i try not to even look at the taco and i just change when i need too depending on the road conditions otherwise i just get too paranoid and instead of looking at the idiots around me, i'm too worried about how many rpm i'm doing, though i have never gone above about 8000rpm (usually i'm around 4-6thou)' in fist 800kms don't rev above 3000rpm'
i've only been riding for just over a week (havnt even got my L's yet) and I havnt had this problem, i think you may mean that when you go frm 3rd-2nd it's not actually IN neutral, but when you use the throttle all it does is rev and your speed doesnt increase??? if that's the case, i was told a "trick", when you change gears, instead of just flicking your foot up/down to change gears and then resting it back on the footpeg, actually hold your toe in the position of the gear you want and then ease off the clutch before you move your foot back as sometimes you don't actually select a gear.sometime when i shift down from 3rd gear to 2nd gear the bike is like at neutral and i have to ease the clutch a bit to make it back to the 2nd gear. is there a problem with the bike or just because of my inexperience?
you should pull in the clutch for all gear changes, down and upMQonNinja wrote:thanks guys. i think i got it!![]()
and here comes another quesion: sometime when i shift down from 3rd gear to 2nd gear the bike is like at neutral and i have to ease the clutch a bit to make it back to the 2nd gear. is there a problem with the bike or just because of my inexperience?
haha was the only thing i can actually help anyone with, otherwise i'm cluelessgood advice shez!!! farking newbie cuts to the chase... we better lift our game!!!
