J1+J2 6R aftermarket/swappable parts list
hey guys, over summer and the coming months i hope to be doing some things to the new ride...and when you're doing that on a bit of a budget then you need to be able to widen your search criteria...
so i think i will start a thread here with aftermaket parts lists and all the bikes that the right part could come from...
i will start with waver rotors from galfer... i will be assuming for the time being that as the galfer part no's are the same that the stock discs would also be a swap...
Brake Discs
front rotors match
ZX6R 95-02
ZX6R 636 03-04
Z750 04-05 (maybe later not sure)
Z1000 03-06
ZX12R 04-05
GPZ1100 95
ZR7 99-04
GPZ900R 90-96
rear rotor matches
ZX6R 98-02 + 07
ZX6RR 03-05
ZX6R 636 03-06
ER6F 06
Z1000 03-06
ZX10R 04-07
2ndclasscitizen
Re: J1+J2 6R aftermarket/swappable parts list
Post by 2ndclasscitizen »
In addition to aftermarket bits, swappable stock parts: Master 98-02 ZX6R Swappable Parts List
thanks 2nd class... have also seen that one ;)
its fun but also frustrating to go looking for parts...
Owen what is wrong with the OEM rotors? You could spend the money more wisely on other go fast stuff... including revalving & setting up the suspension properly for starters ;)
dunno whats wrong with em.... dont think anything is... just a bit of bling...
the brakes do feel wooden but i will change pads and bleed brakes when uni is finished... ;)
