Front sprocket removal trick required ....
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
As subject says ....
If in gear, trying to remove big nut .. turns piston over ...
If on side stand ... turns rear wheel and piston ... ...
I used to do this years ago with my MX bikes without thinking ... now Ive forgotten how to get the farker off! :oops: ... must be old timers disease ... :roll:
Thanks in advance ....
2004 ZRX1200R
And it was good
Re: Front sprocket removal trick required ....
Have you got an impact driver? it would ease the pain
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
robracer wrote:Have you got an impact driver? it would ease the pain
Ya .. right next to the hydraulic lift :roll:
Nah .... socket set with long reach torque bar .. .. :?
2004 ZRX1200R
And it was good
Id be seeing if Dave #3 has one locked away as it is about your only choice of tools if she is on that tight :?
Good luck with it
Team Monster
Post by Disco »
I got an impact wrench and comp. but prolly too far away for you (padstow)......
Issues
Bike: ZZR1100
Post by Issues »
you could try getting someone to stand on the brake lever while you undo the nut. Or man up and get a impact driver, whole $25 :roll:
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
Just sent sms to Dave3 ...
Awaiting gracious response ... ;)
2004 ZRX1200R
And it was good
dave#3
Post by dave#3 »
Sorry mate, I don't got one. You could try a pipe through the rear wheel to lock it (wrap it in a rag first).
http://www.oz4x4.net/gallery2
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
Thanks mate ..
Will stick something (wife?) :shock: through rear wheel ,...
2004 ZRX1200R
And it was good
Get a mate to help, bike in gear and both brakes locked. Problem you have is long reach bar is giving too much torque which is transfered through to the engine. You'll probably do better with a shorted bar and a rubber mallet (similar to how an air ratchet works). Try both but with weight on the bike and bakes applied to stop the bike moving, perhaps even wedge the front up against a wall?
I got a Supercheap compressor and basic tool kit when they were on special - not flash hot, but managed to get the wheel nuts off the Kombi, front sprocket off the 10, rear sprockets off the 6 and even painted fairings. All up, compressor, tools and hose it cost me $150.
Richo
take it from me...GeePeeX7fiddy front sprocket nuts are tuffpharkers to get off
so
either Mike's suggestion...with rattle gun and compressor
or the long breaker bar (holding the bike still is an issue here)
or use an impact driver (with hardened socket please) with BIG smoter :twisted:
to just get its started (then normal socket and ratchet)
hth
Gazza
Post by Gazza »
go buy a can of penatrine and soak the farker first , then let it sit for 12 hours or so
and if that and the above still aint working then get yourself a bigger hammer.
2005 zx10r
6maniac
Post by 6maniac »
Or just take it over to Dave's, drink his beer and watch ! ;)
the kid
Post by the kid »
Standing on the brake and a little heat on the nut may help . Those micro torches have a really fine flame and only cost about $30 from Jaycar , Dick Smith etc .
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
All done ..
Log splitting axe with a big ass rubber handle through the rear wheel ;) Thanks Dave.
Almost fell over when the nut cracked!
Seeyas tomoz 8)
2004 ZRX1200R
And it was good
