WANTED : MUFFLERS TO SUIT 1983 GPZ750
All GPx and GPz Models
mrfista
Bike: GPz750
Post by mrfista »
HI All
i am in need of two mufflers as close to original syle as possible to suit my 1983 gpz750 with 4 into 2 exhaust system.
can anyone tell me what other model exhausts may fit aswell ie gpz,zzr etc...
the weathers getting to nice to be driving.......... i need to ride again
thanks
Re: WANTED : MUFFLERS TO SUIT 1983 GPZ750
You will probably need to get those exact model mufflers - the 83 750 was a Unitrack model, and had different rear mount points than any of the previous twin-shock 750's.
If you were happy to modify a set of 4-2 stock pipes (just at the rear mounting points), then you could possibly use a stock set from a number of early 80's 750s - the early ones are a chrome finish, but I am pretty sure the GT750 (shaft) models were that black-chrome finish used on the GPz750. All the exhaust port spacings and port diameters are the same, so they are all interchangeable (at least at the front).
Good luck - personally I reckon you should fit a nice 4-1 chrome system - they look heaps better ! ;)
mrfista
Bike: GPz750
Post by mrfista »
Cheers Gosling,
a 4 into 1 system would look great but i am trying to keep it as original as possible
thanks for your help
