http://www.ksrc-au.com/phpBB3/viewtopic ... 87#p329387 was the original thread.
My problem is this: from time to time the bike wont start. Press the start button and it goes "click". Doesnt happen all the time - only when you really wish it wouldn't.
Rob suggested the sidestand switch - I've put the bike up on the centre stand and found the switch - gave it a dose of WD40, hit the starter and fired it up first go - excellent!. 3 more time, 3 more starts. 4th hit - click. Damn. (I'm letting the WD40 soak for now and will try again later).
Take it off the center stand, put if 1st, roll forward until the engine engages, put it in neutral, no clutch and hit the starter - starts. This is the only way I've managed to get it started when it's in "click" mode.
To my very limited knowledge it's like the starter is disengaged and the rolling it forward in first gear engages the starter so when I hit the button it starts.
Any other thoughts, suggestions, ideas, recommendations for a good bike mechanic in Penrith?
Wayne
