zx9r gearbox???????????????
gearbox
Post by gearbox »
Hi,does anyone know what could cause the gears to not go in properly when upshifting? It dosen`t do it all the time,about 2 or 3 times on a ride.Oil changes are done evey 4/5000 k`s,{bike has done 40000}cheers GB :? :?
Re: zx9r gearbox???????????????
Could be something as simple as adjusting the clutch cable properly or getting the chain tension right....or if it's a C model ZX9R it could also be something along the lines of this http://www.ksrc-au.com/index.php?itemid=91
....but check the simple things first before panicking about the more serious stuff
Rossi
Post by Rossi »
I'd start by cleaning and greasing the gear change linkage ;)
z900/zx9
Post by z900/zx9 »
Rossi wrote:I'd start by cleaning and greasing the gear change linkage ;)
Yep remove the whole assembly and apply grease to all points,once my bike wouldnt shift up all and i was shitting,but a bit of grease ans alls good ;)
