GPZ900R
Godzilla
GPZ900R
Post by Godzilla »
Hi people,
Any one know if a current model pipe, such as ZX9R, ZRX, GSXR would fit to a GPZ900R? Can be standard or aftermarket.
It is getting hard to source original pipes and the current ones should be better / lighter anyway.
Slight modifications are OK.
Thanks
Regards
Robert
IsleofNinja
Re: GPZ900R
Post by IsleofNinja »
Mine's running a 2 1/4" universal slip on with a custom mid pipe (made my local Carline exhaust shop) in stainless.
Total cost was about $300.00 and has a pretty nice note on her- not too loud yet you know it's there.
You can get later model OEM cans that have a slip joint ie some 600's etc but normally the mounting bracket is not suitable.
(Check ebay for Yoshi cans.. A few around ATM cheap with minor scratches etc which can be polished out.)
You want 2 1/4" inlet (57.5mm) universal fit. If you take bike to local exhaust shop a new mid pipe quick and easy to make for a good exhaust fitter particularly if you remove OEM mid/can for them.
Make sure you get a can with a universal type moveable bracket. Ie you can mount anywhere on the muffler body.
Hope it helps 8)
06 ZX10r , 95 ZX9r
07 FXST
Godzilla
Re: GPZ900R
Post by Godzilla »
Thanks for that.
Sorry, I should have been more exact. Unfortunately I have no exhaust at all, so would need a complete system. So I am hoping that another bikes system may fit with modifications if necessary.
Regards
Robert
IsleofNinja
Re: GPZ900R
You got me curious now!
I might rip me headers off and have a look.. I have a stock 06 zx12R system here .. looks like it might do.. will let you know. 8)
06 ZX10r , 95 ZX9r
07 FXST
lifeofcrimeguy
Re: GPZ900R
Post by lifeofcrimeguy »
Staintune will make anything you want if you take the bike into them, I believe.
See here, young man,
From Walgett to the sea,
-- Banjo Paterson
LMFAO
Godzilla
Re: GPZ900R
Post by Godzilla »
IsleofNinja wrote:You got me curious now!
That would be great.
lifeofcrimeguy wrote:Staintune will make anything you want if you take the bike into them, I believe.
That is the more expensive option.
I would rather buy something that fits or can be modified to fit second hand.
Regards
Robert
Kwak addict
Bike: ZXR750
Re: GPZ900R
Post by Kwak addict »
Post up the measurements of the GeePeeZee exhaust ports (dia, port centre spacing) & distance between bottom of exhaust port & sump & I'll check the stuff I have lying around.
Does the GPZ have the camchain in the middle or on the side?
Ex T.K.A. ZXR 750 RR
ZXR 7/9 L3 Streetfighter
Godzilla
Re: GPZ900R
Post by Godzilla »
Kwak addict wrote:Post up the measurements of the GeePeeZee exhaust ports (dia, port centre spacing) & distance between bottom of exhaust port & sump & I'll check the stuff I have lying around.
I will do that. Unfortunately I do not have access to the GPZ for a couple of weeks. Camchain is on the left hand side looking at it while sitting on it.
Regards
Robert
IsleofNinja
Re: GPZ900R
Cam chain on the left side.
06 ZX10r , 95 ZX9r
07 FXST
