Quick action throttle
Anyone got any info about where to get a good quality quick action throttle... Looking for one that is able to use the original switch block.
Thanks
Re: Quick action throttle
Speak to Gos, he makes them out of plumbing pipe, mine works perfect I love it !
Which bike? If it's for the 10R try {url=http://zx-10r.net/forum/showthread.php?t=12698&highlight=riffleman]Riffleman linky[/url]- posted anywhere in the world for $25US. I think he makes them from a piece of plumbing pipe...
Mine fitted great and I think was worthwhile.
Thanks Guys but I am looking for a complete unit as the pluming pipe & add on bits will not give the adjustment required & being for the 400 the flat slide carbs have a really heavy return spring so a progressive cam action would be best but the cheapest landed is about $300 aus & has 4 different pieces for cable adjustment, a cheap crappy plastic one would probably not last because of the snap from the return spring... yes it is really BAD... these are FCR flatslides not the genuine article. when I say able to use the original switch block I meant in conjunction so therefore the throttle housing needs to be skinny, There seems to be lots of UK suppliers but I would prefer to buy in the US if possible.
Rob
The one that came on my zxr (with the flatslides) was a bit dodgy and ran into the housing through a nylon bush that was wearing away. It was hard to twist and the cap fell of, so I bought a cheap one on ebay to see what they were like. It was similar to the one below, same brand, but had a ball bearing roller (not sure if this one does, though it says it does at the bottom). It worked fine and for the price I'd recommend it, it was one of the few things on the bike that was no trouble.. :?
http://cgi.ebay.com.au/Motorcycle-throt ... dZViewItem
Heres a domino one too.. very similar.
http://cgi.ebay.com.au/genuine-domino-t ... dZViewItem
Thanks Dave The domino ones are Trick & bloody expensive .... I will have a look at both... I am just concerned that the switch block will still fit but I can put it on the other side of the Brake mount leaving more room for this sort of set up... just had a look & it should work ;) cheers
ZX-10R_04
State: Tasmania
Post by ZX-10R_04 »
04 ZX10R & 08 ZX10R
Thanks for the help Guys I have done a buy it now on one similar to Dave's 750 one with the ball bearing race for $50 so I am happy & for the going rate as well :lol: 8)
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
Sorry to butt into the thread here but like learning new things . .(pardon my newbieness) ..
What does a quick action throttle do? ..
Can I assume that she opens up the carbs quicker with less twist on the wrist?? .. or ..other?
Cheers.
2004 ZRX1200R
And it was good
Richo wrote:Sorry to butt into the thread here but like learning new things . .(pardon my newbieness) ..
Cheers.
yep that pretty much sums it up
Richo
Team Chainsaw
Team Chainsaw
Post by Richo »
Fanx ;)
2004 ZRX1200R
And it was good
Richo my little 400 make's power between 10,000 & 14,000 revs & haveing a throttle that is aprox 60 - 70 % turn to WOT (wide open throttle) will be perfect, there are even ones that are available the have a cam action so the power increase is not even to the throttle turn, it is intensified :lol: :twisted:
robracer wrote:Richo my little 400 make's power between 10,000 & 14,000 revs & haveing a throttle that is aprox 60 - 70 % turn to WOT (wide open throttle) will be perfect, there are even ones that are available the have a cam action so the power increase is not even to the throttle turn, it is intensified :lol: :twisted:
then you'll end up with an arm like arnal swartzaneggamassivaarma! :twisted:
Rob - I bunged a Magura throttle assembly onto the trackbike. It is quick action alright - about 1/8 turn !! :shock: just right for the track.
Getting a really good q/a throttle into a stock housing is a bit hard, but it sounds like you have done the job anyway - I am always happy to help newbies out with the good old 'electrical conduit' q/a throttle........as Hoffy says, it works a treat !! :P
(its not plumbing pipe, that shit weighs a ton !! :lol: :lol: )
see you on the road girlfriend !!!
:twisted:
Gosling1 wrote:Getting a really good q/a throttle into a stock housing is a bit hard, but it sounds like you have done the job anyway
Gos I am using the original switch block housing for the switches only... the QA throttle needs to be a seperate unit, but yeah its sorted now
