I want to get some gear and practice with it so i can learn to spray a good even layer of paint, obviously not professional finish, but id like to get to the stage where i can do a pretty good at home finish on bikes with minimal mistakes, runs, and with a decent amount of glossy smooth finish.
i mainly want to do this because i usually just use premixed touch up cans to a pretty good finish, but they come in very limited colours, options, and they suck for reliability some times.
so im looking at some new gear and wanted to know opinions on things like:
guns: looking between 50-100 dollars for medium sized panels, upto the size of a car bonnet basically. so not a full spray your car in one go job, but able to handle some medium panels like fairing.
do i go with gravity feed or vacuum feed, id like to imagine id be hanging the parts up but i know i will always have to tilt the gun a little bit.
also lowpressure or highpressure gun?
compressors: around a 2.5hp enough for a gun? or should i go bigger and bigger tank?
finally whats the majority of the gear i would need to spray paint at home?
compressor with fittings.
gun
thinner
primer
colour
clearcoat
sanding gear
a place to do it
safety gear (breathing stuff mainly, which we got but need new filters)
anything else?
any suggestions on the type of paint to shoot? i have never studied that far either.
regards, chris.
