testing radiator fan
i am suspect my radiator fan isnt workign 100% can i just unplug it from teh loom, and hotwwiare fromt eh battery to test? does it have a fuse?
- JetPilot
Re: testing radiator fan
Yep you can do that.... but only if your not pissed. By thrlook of your typing, y our smashd.rh1an5 wrote:i am suspect my radiator fan isnt workign 100% can i just unplug it from teh loom, and hotwwiare fromt eh battery to test? does it have a fuse?
Kawasaki Z1000r 2012
- Rossi
Remove the plug from the fan switch and use a paperclip to short it out
hahah, yeah my online typing skills leave something to be desired, i tend to type stuff in a hurry and to the wind with spelling and punctuality
rh1an5 wrote:hahah, yeah my online typing skills leave something to be desired, i tend to type stuff in a hurry and to the wind with spelling and punctuality
- mfzx6r
JetPilot wrote:Yep you can do that.... but only if your not pissed. By thrlook of your typing, y our smashd.rh1an5 wrote:i am suspect my radiator fan isnt workign 100% can i just unplug it from teh loom, and hotwwiare fromt eh battery to test? does it have a fuse?
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
'01 zx6r
klx300r
- 6maniac
- Bike: Z750
Rossi wrote:Remove the plug from the fan switch and use a paperclip to short it out
Umm - NOT back to the wiring loom or fuse will blow .
- Rossi
Switches do NOT go to Earth6maniac wrote:Rossi wrote:Remove the plug from the fan switch and use a paperclip to short it out
Please try and keep up at the back
- 6maniac
- Bike: Z750
Not disputing your method - just don't want a non-tech person stuffing up.Rossi wrote:Switches do NOT go to Earth6maniac wrote:Rossi wrote:Remove the plug from the fan switch and use a paperclip to short it out
Umm - NOT back to the wiring loom or fuse will blow .they interrupt the live wire OR in some cases the passage back to earth........known as negative grounding (as in most vehicular systems )
- Rossi
Okay,
Pull the connector off of the fan switch and using a metal paperclip -> connect the two holes in the connector together - make sure the paper clip does NOT come into contact with any metal part of your bike.
The fan should run -> irrespective of the ignition being switched on or off
I have had to change shedloads of fan switches but only 1 fan........mind you, the fan did have a Ford motorcar wedged in it ( tip of the day..........radiator fans do not like motor cars stopping them .......it burns the armature out
Cheers guys, will test it a bit later this morning, any recommendation's for coolant, car coolant is ok?
ok so i can hotwire teh fan, so looks like the switch is dead, anyone have the part number and know approx replacemnt cost?
IIRC it's something like 60 or $70 from Kwaka.
KTM 640LC4 Supermoto, Booya!
- Bike: GPz500
... is it aircooled?
sorry i have nothing useful to post
