REAR SETS - For 06 ZX10R Question..!!
- Maccarocks
Hi all, I am wondering if anyone would know if the rear sets from the 05 model ZX10R will fit the 06 model ZX10R.. as in the hole spacing.. Has anyone tried this... basically I am looking at purchasing a set from the UK, but they say they are for the 04 / 05 model, but the guy selling them reckons they will fit my 06 model as well....?? I will check with my local Kawasaki dealer today as well, just thought I would ask the question... thanks.. Macca
Maccarocks
16' - Z1000 (Road)
16' - Z1000 (Road)
Re: REAR SETS - For 06 ZX10R Question..!!
Not 100% sure, but I'm under the impression they won't fit
- ZX-10R_04
- State: Tasmania
04 ZX10R & 08 ZX10R
04 ZX10R & 08 ZX10R
- Maccarocks
Thanks for the reply.. I thought there was a difference.... so lucky I never purchased the UK ones..?? It always pays to research hey..!! By the way, how does your '10' feel with the extra 2 teeth up on the rear..and the tthrottle insert..?? not too peaky.....??
I have gone down 1 tooth in the front, I have a 1/5th throttle insert but have not installed it yet as i wanted to see how the front sprocket changed the feel at the track.. (you know only doing 1 thing at a time).. I didn't want to make it too peaky.. but after last Friday at the island, I felt the throttle insert would have helped heaps, as I cannot get to full throttle without changing my hand position when heading onto the straight...
Your opinion would be great.. Macca
Maccarocks
16' - Z1000 (Road)
16' - Z1000 (Road)
- ZX-10R_04
- State: Tasmania
Feels way better with 1/5th throttle insert & well worth the money & time for the installation .. Ya dont end up having your elbow near pointing to the ground or wrist cranked right back when twisting the throttle & it helps with a bit quicker acceleration outta the corners .. the +2 teeth on the rear sprocket is a little bit peaky out on the highway but well worth it on track days giving more acceleration outta corners & faster pickup through all gears
& a GIpro TRE will give it even more power through the 1st few gears
04 ZX10R & 08 ZX10R
04 ZX10R & 08 ZX10R
The Horizon becomes closer much quicker with the throttle insert when you first put it in...but you adjust quickly. Its a must do mod, Gos did mine for 47c, used a piece of cut plumbing pipe smoothed off..works a treat.
- Blurr
hey Hoffy how do you find the throttle mod in the burbs and in traffic
- ZX-10R_04
- State: Tasmania
The throttle mod in traffic is pretty good ya end up getting used of how it feels to know how far to twist that throttle
I reckon its one of the best mods I've done so far http://www.doublezracing.com/
04 ZX10R & 08 ZX10R
04 ZX10R & 08 ZX10R
- Maccarocks
Yes I did the throttle mod on my ZX9 and went down 1 tooth on the front sprocket as well... Made a huge difference as I did them both at the same time... dropped my time at the island 2 - 3 secs immediately I would guess.....
I have a TRE installed in the Zx10 track bike as well as 1 tooth down on the front, K+N air filter, gutted cat, power commander 111 and a set of Akros.. it is going really well.. getting much more drive out of the corners in a better gear, much faster than stock.. so the insert will be going in this weekend.. Just wanted to do the changes 1 step at a time so you can feel the difference.. !! Might get into it tonight..??? Thanks for the advice guys...!!! Macca
Maccarocks
16' - Z1000 (Road)
16' - Z1000 (Road)
